[OpenLayers-Dev] Re: Possible bug with Protocol.HTTP
Cody Redmond
codydjango at gmail.com
Wed Jun 15 14:37:46 EDT 2011
Thanks! I already knew about featureselected -- but I must have overlooked
that extra 's'!!!!
Cody
On Tue, Jun 14, 2011 at 9:46 PM, Eric Lemoine
<eric.lemoine at camptocamp.com>wrote:
> On Tue, Jun 14, 2011 at 11:56 PM, codydjango <codydjango at gmail.com> wrote:
> > In this case your callback isn't called because of the Fixed strategy.
> >> The strategy calls protocol.read and provides its own callback to the
> >> read method, so this overrides the "global" callback. If your app code
> >> does protocol.read() somewhere then your "global" callback func will
> >> get invoked.
> > Hello -- I'm new to openlayers, and I've been running into some issues,
> > probably because I'm new. One of the first things I wanted to do was
> draw a
> > box, have the server return all the features in the box, and then "do
> > something" with them.
> > I thought I'd use something like this:
> > var getFeatures = new OpenLayers.Control.GetFeature({
> > box: true,
> > click: false,
> > multiple: true,
> > protocol: new OpenLayers.Protocol.HTTP({
> > url: '/obj',
> > format: new OpenLayers.Format.GeoJSON(),
> > params: {
> > limit: 2000
> > What is the best way to set a custom callback to go off once their is
> > response data to work with?
> The control triggers "featuresselected" events when features are received.
> box: true,
> click: false,
> multiple: true,
> url: '/obj',
> params: {
> limit: 2000
> eventListeners: {
> featuresselected: function(e) {
> // do something with e.features
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110615/b9e9cd26/attachment.html
More information about the Dev
