[OpenLayers-Dev] Error in SelectFeature with previous highlight? etc.
Slawomir Messner slawomir.messner at staff.uni-marburg.de
Mon Jun 27 07:11:44 EDT 2011
we use two SelectFeature controls one for highlight and the other for
select. For the highlight control is hover and highlightOnly true, the
select control selects by click, multiKey or boxKey. Now when I click
one feature it's selected when I then click an other feature the first
is highlighted and the other is selected.
I think the error could be in the outFeature- function of SelectFeature
where only something happens when the control is the current highlighter
(feature._lastHightlighter is set to this SelectFeature). I think the
control should delete itself from the feature when it is the
feature._prevHightlighter.
     outFeature: function(feature) {
         if(this.hover) {
             if(this.highlightOnly) {
                 // we do nothing if we're not the last highlighter of the
                 // feature
                 if(feature._lastHighlighter == this.id) {
                     // if another select control had highlighted the
feature before
                     // we did it ourself then we use that control to
highlight the
                     // feature as it was before we highlighted it, else
we just
                     // unhighlight it
                     if(feature._prevHighlighter &&
                        feature._prevHighlighter != this.id) {
                         delete feature._lastHighlighter;
                         var control = this.map.getControl(
                             feature._prevHighlighter);
                         if(control) {
                             control.highlight(feature);
                     } else {
                         this.unhighlight(feature);
                 } *else if (feature._prevHighlighter == this.id) {
                     delete feature._prevHighlighter;
             } else {
                 this.unselect(feature);
Is it a bug (ours or in OL) or a feature?
By the way, someone looked for these two tickets:
http://trac.osgeo.org/openlayers/ticket/1971
and
http://trac.osgeo.org/openlayers/ticket/3257
Regards
Slawomir
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20110627/42a5c1e6/attachment.html
More information about the Dev mailing list
