[OpenLayers-Dev] geolocation example
Noli Sicad
nsicad at gmail.com
Mon Jun 27 07:12:08 EDT 2011
Hi Pierre,
It seems that the online example is working.
I must probably the modification that I made on Geolocation.js.
However, as far I can remember, the 2.10 example is not working as
well. Or it might be that the example is not working when it is not on
a server?
I will copy the online and see if it is working without a server.
Thanks.
Regards, Noli
On 6/27/11, Pierre Giraud <pierre.giraud at camptocamp.com> wrote:
> Hello,
> I don't have any problem in FF3.6.
> You tell us that you tried it before and after the revision. Was it
> working before my modifications ?
> Can you confirm that the online example isn't working for you ?
> http://openlayers.org/dev/examples/geolocation.html
> Regards,
> Pierre
> On Mon, Jun 27, 2011 at 8:14 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi Pierre,
>> It seems that the Geolocation.html in OpenLayers 2.11 RC does not work.
>> I tried it before and after the revision. It is not working in Mac OS
>> X 10.6.4 in Firefox 3.6.x and Safari. Yes, it is asking for my
>> location but it is displaying in the map.
>> Would it be possible to post me, working copy (i.e. Geolocation.html
>> and Geolocation.js)?
>> Thanks.
>> Regards, Noli
>> On 6/21/11, Pierre Giraud <pierre.giraud at camptocamp.com> wrote:
>>> Hi all,
>>> I just changed the geolocation example [1].
>>> The purpose was to prevent the map to be zoomed more than once when
>>> tracking user position.
>>> Now if the user checks the "track my position", the map will be zoomed
>>> and the circle will pulsate. Then, the map will be recentered to
>>> user's position each time he moves. But, he's allowed to zoom out. The
>>> zoom level will be kept until he clicks on the "locate me" button.
>>> I think this use case is common and I hope this addition makes sense.
>>> Regards,
>>> Pierre
>>> [1] http://trac.osgeo.org/openlayers/changeset/12117
>>> Pierre GIRAUD
>>> Géomaticien, Analyste
>>> Camptocamp France SAS
>>> Savoie Technolac, BP 352
>>> 73377 Le Bourget du Lac, Cedex
>>> Tel : 00 33 4 79 44 44 93
>>> Mail : pierre.giraud at camptocamp.com
>>> http://www.camptocamp.com
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Pierre GIRAUD
More information about the Dev
