[OpenLayers-Dev] geolocation example
Noli Sicad nsicad at gmail.com
Mon Jun 27 07:30:01 EDT 2011
I think there is nothing wrong with the example.
The funny thing is I only get it working once in firefox and it is not
working again in both firefox and Safari. I think my internet
connection - 3G broadband is causing geolocation not working properly.
My compiled Openlayers app i.e Hybrid app - (Xcode and OpenLayers)
geolocation works well in iPad Simulator. However, the regular
OpenLayers in the web browser, geolocation got problem of Locate and
track null objects.
Thanks.
Regards, Noli
On 6/27/11, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Pierre,
> It seems that the online example is working.
> I must probably the modification that I made on Geolocation.js.
> However, as far I can remember, the 2.10 example is not working as
> well. Or it might be that the example is not working when it is not on
> a server?
> I will copy the online and see if it is working without a server.
> Thanks.
> Regards, Noli
> On 6/27/11, Pierre Giraud <pierre.giraud at camptocamp.com> wrote:
>> Hello,
>> I don't have any problem in FF3.6.
>> You tell us that you tried it before and after the revision. Was it
>> working before my modifications ?
>> Can you confirm that the online example isn't working for you ?
>> http://openlayers.org/dev/examples/geolocation.html
>> Regards,
>> Pierre
>> On Mon, Jun 27, 2011 at 8:14 AM, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Pierre,
>>> It seems that the Geolocation.html in OpenLayers 2.11 RC does not work.
>>> I tried it before and after the revision. It is not working in Mac OS
>>> X 10.6.4 in Firefox 3.6.x and Safari. Yes, it is asking for my
>>> location but it is displaying in the map.
>>> Would it be possible to post me, working copy (i.e. Geolocation.html
>>> and Geolocation.js)?
>>> Thanks.
>>> Regards, Noli
>>> On 6/21/11, Pierre Giraud <pierre.giraud at camptocamp.com> wrote:
>>>> Hi all,
>>>> I just changed the geolocation example [1].
>>>> The purpose was to prevent the map to be zoomed more than once when
>>>> tracking user position.
>>>> Now if the user checks the "track my position", the map will be zoomed
>>>> and the circle will pulsate. Then, the map will be recentered to
>>>> user's position each time he moves. But, he's allowed to zoom out. The
>>>> zoom level will be kept until he clicks on the "locate me" button.
>>>> I think this use case is common and I hope this addition makes sense.
>>>> Regards,
>>>> Pierre
>>>> [1] http://trac.osgeo.org/openlayers/changeset/12117
>>>> Pierre GIRAUD
>>>> Géomaticien, Analyste
>>>> Camptocamp France SAS
>>>> Savoie Technolac, BP 352
>>>> 73377 Le Bourget du Lac, Cedex
>>>> Tel : 00 33 4 79 44 44 93
>>>> Mail : pierre.giraud at camptocamp.com
>>>> http://www.camptocamp.com
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Pierre GIRAUD
More information about the Dev mailing list
