[OpenLayers-Dev] Issue with TMS - works for 2.7, but not 2.10
Phil Scadden p.scadden at gns.cri.nz
Tue Mar 1 23:23:09 EST 2011
I've been generating tiles with MapTiler that creates a stub for
openlayers to look at the file. Change this
to my local Openlayers-2.10 and it stops working.
The issue occurs with initGriddedTiles and the call to addTile. This is
supposed to be implemented by subclass but not.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml>"
<head>
<title>Reservoir Potential-32.png</title>
<meta http-equiv='imagetoolbar' content='no'/>
<style type="text/css"> v\:* {behavior:url(#default#VML);}
                 html, body { overflow: hidden; padding: 0; height:
100%; width: 100%; font-family: 'Lucida
Grande',Geneva,Arial,Verdana,sans-serif; }
                 body { margin: 10px; background: #fff; }
                 h1 { margin: 0; padding: 6px; border:0; font-size: 20pt; }
                 #header { height: 43px; padding: 0; background-color:
#eee; border: 1px solid #888; }
                 #subheader { height: 12px; text-align: right;
font-size: 10px; color: #555;}
                 #map { height: 95%; border: 1px solid #888; }
</style>
<script
src='http://maps.google.com/maps?file=api&amp;v=2&amp;key=INSERT_YOUR_KEY_HERE'
type='text/javascript'></script>
<script src="http://www.openlayers.org/api/2.7/OpenLayers.js"
type="text/javascript"></script>
<script type="text/javascript">
                 var map;
                 var mapBounds = new OpenLayers.Bounds( 171.557011392,
-41.01960226, 175.486543045, -37.9967509295);
                 var mapMinZoom = 6;
                 var mapMaxZoom = 10;
                 // avoid pink tiles
                 OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
                 OpenLayers.Util.onImageLoadErrorColor = "transparent";
                 function init(){
                 var options = {
                     controls: [],
                     projection: new OpenLayers.Projection("EPSG:900913"),
                     displayProjection: new
OpenLayers.Projection("EPSG:4326"),
                     units: "m",
                     maxResolution: 156543.0339,
                     maxExtent: new OpenLayers.Bounds(-20037508,
-20037508, 20037508, 20037508.34)
                 map = new OpenLayers.Map('map', options);
                 // create Google Mercator layers
                 var gmap = new OpenLayers.Layer.Google("Google Streets",
                     { sphericalMercator: true, numZoomLevels: 20} );
                 var gsat = new OpenLayers.Layer.Google("Google Satellite",
                     {type: G_SATELLITE_MAP, sphericalMercator: true,
                 var ghyb = new OpenLayers.Layer.Google("Google Hybrid",
                     {type: G_HYBRID_MAP, sphericalMercator: true,
numZoomLevels: 20});
                 var gter = new OpenLayers.Layer.Google("Google Terrain",
                     {type: G_PHYSICAL_MAP, sphericalMercator: true,
numZoomLevels: 20 });
                 // create OSM/OAM layer
                 // create TMS Overlay layer
                 var tmsoverlay = new OpenLayers.Layer.TMS( "TMS
Overlay", "data/TaranakiAtlas/Reservoir Potential-32/",
                     {    //url: '', serviceVersion: '.', layername: '.',
                         type: 'png', getURL: overlay_getTileURL, alpha:
true,
                         isBaseLayer: false
                 if (OpenLayers.Util.alphaHack() == false) {
tmsoverlay.setOpacity(0.7); }
                 map.addLayers([gmap, gsat, ghyb, gter,
                                tmsoverlay]);
                 var switcherControl = new
OpenLayers.Control.LayerSwitcher();
                 map.addControl(switcherControl);
                 switcherControl.maximizeControl();
                 map.zoomToExtent(
mapBounds.transform(map.displayProjection, map.projection ) );
                 map.addControl(new OpenLayers.Control.PanZoomBar());
                 map.addControl(new OpenLayers.Control.MousePosition());
                 map.addControl(new OpenLayers.Control.MouseDefaults());
                 map.addControl(new OpenLayers.Control.KeyboardDefaults());
             function overlay_getTileURL(bounds) {
                 var res = this.map.getResolution();
                 var x = Math.round((bounds.left - this.maxExtent.left)
/ (res * this.tileSize.w));
                 var y = Math.round((bounds.bottom -
this.tileOrigin.lat) / (res * this.tileSize.h));
                 var z = this.map.getZoom();
                 if (this.map.baseLayer.name == 'Virtual Earth Roads' ||
this.map.baseLayer.name == 'Virtual Earth Aerial' ||
this.map.baseLayer.name == 'Virtual Earth Hybrid') {
                    z = z + 1;
                 if (mapBounds.intersectsBounds( bounds ) && z >=
mapMinZoom && z <= mapMaxZoom ) {
                    //console.log( this.url + z + "/" + x + "/" + y +
"." + this.type);
                    return this.url + z + "/" + x + "/" + y + "." +
this.type;
                 } else {
                    return "images/none.png";
</script>
</head>
<body onload="init()">
<div id="header"><h1>Reservoir Potential-32.png</h1></div>
<div id="subheader">Generated by <a
href="http://www.maptiler.org/">MapTiler</a>/<a
href="http://www.klokan.cz/projects/gdal2tiles/">GDAL2Tiles</a>,
Copyright &copy; 2008 <a href="http://www.klokan.cz/">Klokan Petr
Pridal</a>, <a href="http://www.gdal.org/">GDAL</a> &amp; <a
href="http://www.osgeo.org/">OSGeo</a> <a
href="http://code.google.com/soc/">GSoC</a>
<!-- PLEASE, LET THIS NOTE ABOUT AUTHOR AND PROJECT SOMEWHERE ON YOUR
WEBSITE, OR AT LEAST IN THE COMMENT IN HTML. THANK YOU -->
</div>
<div id="map"></div>
<script type="text/javascript" >resize()</script>
</body>
</html>
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev mailing list
