[OpenLayers-Dev] Re: OSM layer panning at trunk
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Thu Mar 3 02:11:18 EST 2011
The default value of buffer was changed from 2 to 0, which probably
explains this?
Best regards,
Bart
> http://gis-lab.info/share/DR/sandbox/osm-release.html
> http://gis-lab.info/share/DR/sandbox/osm-trunk.html
> On Thu, Mar 3, 2011 at 1:01 PM, Denis Rykov <rykovd at gmail.com> wrote:
>> Hi devs!
>> I've made two examples with different version of OpenLayers - 2.10 and
>> trunk version.
>> Both examples contains map with one OSM layer and shows different
>> behavior while map panning.
>> I guess that at the second (trunk) example while panning tiles loads
>> only after moveend event, but in the first example it does not.
>> Could anyone explain this behavior?
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
