[OpenLayers-Dev] Re: OSM layer panning at trunk
Bruno Binet
bruno.binet at camptocamp.com
Thu Mar 3 02:33:24 EST 2011
Or because of this:
http://trac.osgeo.org/openlayers/ticket/2998
On 3 March 2011 08:11, Bart van den Eijnden (OSGIS) <bartvde at osgis.nl> wrote:
> The default value of buffer was changed from 2 to 0, which probably
> explains this?
> Best regards,
> Bart
>> http://gis-lab.info/share/DR/sandbox/osm-release.html
>> http://gis-lab.info/share/DR/sandbox/osm-trunk.html
>> On Thu, Mar 3, 2011 at 1:01 PM, Denis Rykov <rykovd at gmail.com> wrote:
>>> Hi devs!
>>> I've made two examples with different version of OpenLayers - 2.10 and
>>> trunk version.
>>> Both examples contains map with one OSM layer and shows different
>>> behavior while map panning.
>>> I guess that at the second (trunk) example while panning tiles loads
>>> only after moveend event, but in the first example it does not.
>>> Could anyone explain this behavior?
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
Bruno Binet
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Mail : bruno.binet at camptocamp.com
http://www.camptocamp.com
More information about the Dev
