[OpenLayers-Dev] Re: More undefined variables on OpenLayers!
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue Mar 8 03:58:27 EST 2011
Hi Tim Schaub,
I think it would be interesting if any developer could easily use the
Closure Compiler in this way as part of the tests.
For this reason I investigated the use of Closure and wrote #2972 and later
http://trac.osgeo.org/openlayers/ticket/3008.
(the current implementation of Closure in OL not allow this use, and should
be reviewed: does not work on Windows see #3158)
Now #3008 is Milestone Future. I think it would be interesting to implement
some of its parts in 2.11
Regards,
Xavier Mamano
Tim Schaub wrote:
> On 3/7/11 2:29 PM, Xavier Mamano (jorix) wrote:
>> Hi,
>> Using Closure Compiler is possible to have a report of all undefined
>> variables.
>> Now this is the result:
>> ..\lib\OpenLayers\Layer\Grid.js:704: ERROR - variable tlViewPort is
>> undefined
>> tlViewPort = tlLayer.add(offsetX, offsetY);
> http://trac.osgeo.org/openlayers/changeset/11663/
>> ..\lib\OpenLayers\Map.js:1692: ERROR - variable yRestriction is undefined
>> var xRestriction = yRestriction = 0;
> http://trac.osgeo.org/openlayers/changeset/11664/
>> ..\lib\OpenLayers\Renderer\SVG2.js:655: ERROR - variable component is
>> undefined
>> component = components[i];
> http://trac.osgeo.org/openlayers/changeset/11665/
>> 3 error(s), 26 warning(s)
> Thanks for the vigilance.
> Tim
>> (now is not possible get this report using "build.py -c closure")
>> Xavier Mamano
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/More-undefined-variables-on-OpenLayers-tp6099332p6099332.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
View this message in context: http://osgeo-org.1803224.n2.nabble.com/More-undefined-variables-on-OpenLayers-tp6099332p6115872.html
More information about the Dev mailing list
