[OpenLayers-Dev] click & pinch overhaul
Bruno Binet
bruno.binet at camptocamp.com
Wed Mar 9 18:54:37 EST 2011
Great job, thanks for your work on all this!
As a general feedback, the pinch and click handlers are now working
very well together on my samsung android 2.1 device, and I can now
pinch zoom, and zoom out by tapping with two fingers as expected.
Btw, a small annoyance remains with the pinch handler while working
with the drag handler: if I drag the map with one finger then add a
second finger, the pinch handler successfully handles the pinch
gestures, but if I lift the second finger off the touchscreen, then I
can't drag anymore by keeping the first finger on the screen.
That's a minor feature request, and it is even not related to the
click handler, so it could deserve a separate ticket if it sounds
reasonable to you.
On 9 March 2011 08:11, Tim Schaub <tschaub at opengeo.org> wrote:
> I've updated the sandbox with two changes:
> 1) Double click pixel tolerance is now 13. This should give fewer ignored
> double clicks.
The tests were broken in the sandbox because of the new double click
pixel tolerance value. The fix was trivial so I've just fixed the
tests in r11687 directly in your sandbox. Hope it's fine for you.
> 2) The pinch handler now stops the browser default behavior on handled touch
> move events. This may stop the page drag on older iOS.
> http://dev.openlayers.org/sandbox/tschaub/click/examples/mobile.html
> I'm still unclear about whether the undesired page dragging only occurs in
> the sandbox example, or whether you also see it on the trunk.
> Thanks for the testing & feedback.
> Tim
> On 3/8/11 2:08 PM, Cédric MOULLET wrote:
>> Hi Tim,
>> It's really a great function, and so fast !!!
>> I put two answers inline,
>> Cédric
>> On Tue, Mar 8, 2011 at 8:48 AM, Tim Schaub <tschaub at opengeo.org
>> <mailto:tschaub at opengeo.org>> wrote:
>> Thanks for the report Cédric. Comments below.
>> On 3/7/11 10:49 AM, Cédric MOULLET wrote:
>> Hi Tim,
>> Thanks for these improvements. I have tested on several
>> plattforms (see
>> https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0
>> <https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0>
>> <https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0>>).
>> I face the same issues like Steven. In addition, I have observed
>> the
>> following things:
>> - iTouch 3.1.3: Pinch Zoom Dragging -> it moves the browser
>> instead of
>> the map and makes the function ineffective
>> I also saw the same on an iTouch before upgrading. But I'm pretty
>> sure I saw it on the trunk (instead of just on this sandbox). Are
>> you seeing the issue in this sandbox and not on the trunk? (I've
>> only got access to an upgraded iTouch, and pinch zooming works there.)
>> I have tested on your sandbox: Here is a small video that presents the
>> issue:
>> http://www.youtube.com/watch?v=6VoVKeOy9dg&feature=player_embedded
>> <http://www.youtube.com/watch?v=6VoVKeOy9dg&feature=player_embedded>
>> (sorry for the quality, but I'm not Spielberg). I can observe that the
>> pinch function is working, but the browser window moves. I don't observe
>> that on the iPad 4.2. If it's an iOS version issue, I don't think it's
>> so important.
>> - Android Nexus S: the double click seems to work a bit better,
>> but has
>> still issues. No idea why (but this is a very empirical
>> observation)
>> Sounds like the 10 pixel tolerance for double clicks may not be enough.
>> I'd be curious what you see for pixel displacement on typical
>> double-tap sequences (on a touch device).
>> http://dev.openlayers.org/sandbox/tschaub/click/examples/dpx.html
>> I have added an average and standard deviation function:
>> http://dev.openlayers.org/sandbox/cmoullet/openlayers/examples/dpx.html
>> iTouch 3.1.3: pair: 30 - avg: 4.2 - std: 3.1
>> iPad 4.2: pair 30 - avg 6.7 - std: 2.5
>> Android Nexus S: pair 30 - avg: 8.3 - std: 4.5
>> These are of course very empirical results, but it seems that I'm less
>> precise on an Android nexus S. So the tolerance should be a bit bigger.
> Tim Schaub
> OpenGeo - http://opengeo.org
> Expert service straight from the developers.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Bruno Binet
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Mail : bruno.binet at camptocamp.com
http://www.camptocamp.com
More information about the Dev
