[OpenLayers-Dev] click & pinch overhaul
Tim Schaub tschaub at opengeo.org
Wed Mar 9 19:50:07 EST 2011
On 3/9/11 3:54 PM, Bruno Binet wrote:
> Great job, thanks for your work on all this!
> As a general feedback, the pinch and click handlers are now working
> very well together on my samsung android 2.1 device, and I can now
> pinch zoom, and zoom out by tapping with two fingers as expected.
> Btw, a small annoyance remains with the pinch handler while working
> with the drag handler: if I drag the map with one finger then add a
> second finger, the pinch handler successfully handles the pinch
> gestures, but if I lift the second finger off the touchscreen, then I
> can't drag anymore by keeping the first finger on the screen.
> That's a minor feature request, and it is even not related to the
> click handler, so it could deserve a separate ticket if it sounds
> reasonable to you.
Thanks for taking time to look at this Bruno.  Unless others see it as a
blocker, I think the issue you mention above should be treated as a
separate feature.
Tomorrow I'm leaving town for a week+.  I'm hoping to be able to get in
these changes (and others) before leaving.  I know the change is big,
but if anybody can review the patch, I'd appreciate it.
http://trac.osgeo.org/openlayers/ticket/3133
Thanks,
Tim
> On 9 March 2011 08:11, Tim Schaub<tschaub at opengeo.org>  wrote:
>> I've updated the sandbox with two changes:
>> 1) Double click pixel tolerance is now 13.  This should give fewer ignored
>> double clicks.
> The tests were broken in the sandbox because of the new double click
> pixel tolerance value. The fix was trivial so I've just fixed the
> tests in r11687 directly in your sandbox. Hope it's fine for you.
>> 2) The pinch handler now stops the browser default behavior on handled touch
>> move events.  This may stop the page drag on older iOS.
>> http://dev.openlayers.org/sandbox/tschaub/click/examples/mobile.html
>> I'm still unclear about whether the undesired page dragging only occurs in
>> the sandbox example, or whether you also see it on the trunk.
>> Thanks for the testing&  feedback.
>> Tim
>> On 3/8/11 2:08 PM, Cédric MOULLET wrote:
>>> Hi Tim,
>>> It's really a great function, and so fast !!!
>>> I put two answers inline,
>>> Cédric
>>> On Tue, Mar 8, 2011 at 8:48 AM, Tim Schaub<tschaub at opengeo.org
>>> <mailto:tschaub at opengeo.org>>  wrote:
>>>     Thanks for the report Cédric.  Comments below.
>>>     On 3/7/11 10:49 AM, Cédric MOULLET wrote:
>>>         Hi Tim,
>>>         Thanks for these improvements. I have tested on several
>>>         plattforms (see
>>>   https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0
>>>   <https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0>
>>>   <https://spreadsheets.google.com/ccc?key=0AjTbLQNm01pfdEtUc0FkVm9DYnBtMTNkcWpTemw3T0E&authkey=CJGm_vQF&hl=fr#gid=0>>).
>>>         I face the same issues like Steven. In addition, I have observed
>>> the
>>>         following things:
>>>         - iTouch 3.1.3: Pinch Zoom Dragging ->  it moves the browser
>>>         instead of
>>>         the map and makes the function ineffective
>>>     I also saw the same on an iTouch before upgrading.  But I'm pretty
>>>     sure I saw it on the trunk (instead of just on this sandbox).  Are
>>>     you seeing the issue in this sandbox and not on the trunk?  (I've
>>>     only got access to an upgraded iTouch, and pinch zooming works there.)
>>> I have tested on your sandbox: Here is a small video that presents the
>>> issue:
>>> http://www.youtube.com/watch?v=6VoVKeOy9dg&feature=player_embedded
>>> <http://www.youtube.com/watch?v=6VoVKeOy9dg&feature=player_embedded>
>>> (sorry for the quality, but I'm not Spielberg). I can observe that the
>>> pinch function is working, but the browser window moves. I don't observe
>>> that on the iPad 4.2. If it's an iOS version issue, I don't think it's
>>> so important.
>>>         - Android Nexus S: the double click seems to work a bit better,
>>>         but has
>>>         still issues. No idea why (but this is a very empirical
>>> observation)
>>>     Sounds like the 10 pixel tolerance for double clicks may not be enough.
>>>     I'd be curious what you see for pixel displacement on typical
>>>     double-tap sequences (on a touch device).
>>>     http://dev.openlayers.org/sandbox/tschaub/click/examples/dpx.html
>>> I have added an average and standard deviation function:
>>> http://dev.openlayers.org/sandbox/cmoullet/openlayers/examples/dpx.html
>>> iTouch 3.1.3: pair: 30 - avg: 4.2 - std: 3.1
>>> iPad 4.2: pair 30 - avg 6.7 - std: 2.5
>>> Android Nexus S: pair 30 - avg: 8.3 - std: 4.5
>>> These are of course very empirical results, but it seems that I'm less
>>> precise on an Android nexus S. So the tolerance should be a bit bigger.
>> Tim Schaub
>> OpenGeo - http://opengeo.org
>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Tim Schaub
More information about the Dev mailing list
