[OpenLayers-Dev] Re: MousePosition Control Issue
dr
rykovd at gmail.com
Wed Mar 9 22:53:27 EST 2011
Tim, thanks for the clarification. Is it possible to get the same coordinates
(degrees) for different layers? I try set different values of map.projection
property, but it doesn't work.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MousePosition-Control-Issue-tp6153074p6156477.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
