[OpenLayers-Dev] WMSCapabilities parsing causing memory spike
Andreas Hocevar
ahocevar at opengeo.org
Thu Mar 24 05:42:08 EDT 2011
A known issue is that capabilities parsing is slower than it has to be. The memory consumption may be related to this. See http://trac.osgeo.org/openlayers/ticket/3187
Regards,
Andreas.
On Mar 8, 2011, at 21:33 , KevinGreen24 wrote:
> I was recently working on some javascript code which took the text response
> from a WMS Get Capabilities call and used OpenLayers' formatting to parse it
> into an array of features:
> var CAPformat = new OpenLayers.Format.WMSCapabilities();
> var capabilities = CAPformat.read(wmsString);
> I've noticed that the call to .read causes a memory spike of 2-300 MB of
> utilized web browser memory that does not get cleaned up, even if .destroy()
> is called on the CAPformat object. I have made 3 consecutive calls to this
> code and have seen Firefox.exe consume 1.2 GB of memory. Has anyone else
> encountered this issue and have a resolution to it?
> FYI here's a URL i was testing against to make the get capabilities call:
> http://giswebservices.massgis.state.ma.us/geoserver/wms
> Thank you,
> -KG
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WMSCapabilities-parsing-causing-memory-spike-tp6140541p6140541.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
