[OpenLayers-Dev] #1633: remove dependency on popup and marker from
vector feature
Frederic Junod
frederic.junod at camptocamp.com
Wed Mar 30 06:12:35 EDT 2011
Hello,
http://trac.osgeo.org/openlayers/ticket/1633 removes the dependency on
AnchoredBubble and Marker from OpenLayers.Feature in order to get
smaller build.
The proposed patch removes the two requires, adapt the code and unit
tests without functionality change.
But there's a backward incompatibility change: with custom build, the
createPopup and createMarker functions will require the two files to
be manually added to the build config file.
I think that adding a note on
http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes is
sufficient.
Do you agree ?
fredj
Frédéric Junod
Camptocamp SA
More information about the Dev
