[OpenLayers-Dev] #1633: remove dependency on popup and marker from vector feature
Marc Jansen jansen at terrestris.de
Wed Mar 30 09:50:49 EDT 2011
Hi Frederic,
On 30.03.2011 12:12, Frederic Junod wrote:
> Hello,
> http://trac.osgeo.org/openlayers/ticket/1633 removes the dependency on
> AnchoredBubble and Marker from OpenLayers.Feature in order to get
> smaller build.
> The proposed patch removes the two requires, adapt the code and unit
> tests without functionality change.
> But there's a backward incompatibility change: with custom build, the
> createPopup and createMarker functions will require the two files to
> be manually added to the build config file.
> I think that adding a note on
> http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes is
> sufficient.
> Do you agree ?
> fredj
+1
Regards,
Marc
More information about the Dev mailing list
