[OpenLayers-Dev] #1633: remove dependency on popup and marker from vector feature
Frederic Junod frederic.junod at camptocamp.com
Wed Mar 30 10:23:15 EDT 2011
Thanks, the patch is commited and a note has been added to
http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes
fredj
On Wed, Mar 30, 2011 at 3:50 PM, Marc Jansen <jansen at terrestris.de> wrote:
> Hi Frederic,
> On 30.03.2011 12:12, Frederic Junod wrote:
>> Hello,
>> http://trac.osgeo.org/openlayers/ticket/1633 removes the dependency on
>> AnchoredBubble and Marker from OpenLayers.Feature in order to get
>> smaller build.
>> The proposed patch removes the two requires, adapt the code and unit
>> tests without functionality change.
>> But there's a backward incompatibility change: with custom build, the
>> createPopup and createMarker functions will require the two files to
>> be manually added to the build config file.
>> I think that adding a note on
>> http://trac.osgeo.org/openlayers/wiki/Release/2.11/Notes is
>> sufficient.
>> Do you agree ?
>> fredj
> +1
> Regards,
> Marc
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Frédéric Junod
Camptocamp SA
More information about the Dev mailing list
