[OpenLayers-Dev] Re: There's something broken in
"Addins/TimedPointTrack "
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Thu Nov 17 17:26:29 EST 2011
Hi Andreas,
The track is loaded correctly but I mistook the scroll bar as a zoom (I was
looking a horizontal bar) Sorry!
Interesting!
Bug: If after you have moved the bar reloads the data then the bar is
located at the beginning but the point not. From here, the bar has a strange
behavior, even the slider goes out, over the top.
Xavier Mamano
Andreas Hocevar-2 wrote:
> You have to load a georss file first. The track1.xml works when you click
> Load.
> Andreas.
> On Nov 17, 2011 6:46 PM, "Xavier Mamano (jorix)" <xavier.mamano@>
> wrote:
>> Hi,
>> In the example
>> http://dev.openlayers.org/addins/timedpointtrack/trunk/examples/time-select-control.html
>> the Control.TimeSliderBar do not appear. Only a text "Unknown" is
>> displayed
>> in the lower left corner of the map.
>> Tested with FF8 and Chrome15
>> Xavier Mamano
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/There-s-something-broken-in-Addins-TimedPointTrack-tp7005045p7005045.html
>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>> Dev mailing list
>> Dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
> Dev at .osgeo
View this message in context: http://osgeo-org.1803224.n2.nabble.com/There-s-something-broken-in-Addins-TimedPointTrack-tp7005045p7006100.html
More information about the Dev
