[OpenLayers-Dev] Re: There's something broken in "Addins/TimedPointTrack "
Andreas Hocevar ahocevar at opengeo.org
Thu Nov 17 17:47:04 EST 2011
the bug you mention is an issue with the example only, because the case of adding another layer is not handled (clicking "Load Feed" again does not reload the layer, it adds another one).
Andreas.
On Nov 17, 2011, at 23:26 , Xavier Mamano (jorix) wrote:
> Hi Andreas,
> The track is loaded correctly but I mistook the scroll bar as a zoom (I was
> looking a horizontal bar) Sorry!
> Interesting!
> Bug: If after you have moved the bar reloads the data then the bar is
> located at the beginning but the point not. From here, the bar has a strange
> behavior, even the slider goes out, over the top.
> Xavier Mamano
> Andreas Hocevar-2 wrote:
>> You have to load a georss file first.  The track1.xml works when you click
>> Load.
>> Andreas.
>> On Nov 17, 2011 6:46 PM, "Xavier Mamano (jorix)" <xavier.mamano@>
>> wrote:
>>> Hi,
>>> In the example
>>> http://dev.openlayers.org/addins/timedpointtrack/trunk/examples/time-select-control.html
>>> the Control.TimeSliderBar do not appear. Only a text "Unknown" is
>>> displayed
>>> in the lower left corner of the map.
>>> Tested with FF8 and Chrome15
>>> Xavier Mamano
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/There-s-something-broken-in-Addins-TimedPointTrack-tp7005045p7005045.html
>>> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
>>> Dev mailing list
>>> Dev at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
>> Dev at .osgeo
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/There-s-something-broken-in-Addins-TimedPointTrack-tp7005045p7006100.html
> Dev mailing list
> Dev at lists.osgeo.org
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
