[OpenLayers-Dev] Gpx vector layer not displayed
Tobias Reinicke ramotswa at gmail.com
Fri Oct 7 06:48:08 EDT 2011
When I run  your site I get a 404 error regarding the .sdx file. It
can't find it (which is probably your problem).
It's looking here:
GET http://mura-drava-bike.com/gpxtest/gpx/myosmfile.gpx 404 (Not Found)
Make sure the path in url: "gpx/myosmfile.gpx", is correct.
Toby
On 7 October 2011 11:43, nikolaHr <smetlishte at gmail.com> wrote:
> Hi, I have problem rendering vector layer on top of map only when is viewed
> from server side.
> I'm using openlayers in combination with gpx file (and txt files for poi
> locations around route).
> Please, someone look my code and help me figure what I'm doing wrong. There
> should be red route over map!
> Here is link on webpage:
> and link to function:
> http://mura-drava-bike.com/gpxtest/js/myFunctions.js
> Vector layer is in *trasa *variable (line 20), called to render (line 35).
> So. there should be red vector line representing route from gpx file, but it
> is not. That is problem.
> p.s. when viewing locally on my pc, *everything *is fine and working
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Gpx-vector-layer-not-displayed-tp6868869p6868869.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
