[OpenLayers-Dev] OpenLS - XLS - Routing
Bart van den Eijnden
bartvde at osgis.nl
Mon Oct 24 10:47:49 EDT 2011
Hi Maria,
I did some of the initial implementation, so if you have any questions feel free to ask.
Instead of a sandbox, you can also fork OpenLayers on github:
https://github.com/openlayers/openlayers
Good luck and looking forward to your contribution!
Best regards,
Bart
OSGIS - http://osgis.nl
On Oct 24, 2011, at 4:44 PM, Maria Arias de Reyna wrote:
> Hi there,
> I need a routing openLS client[1] for OpenLayers and I see that there have
> been some serious effort [2] done to implement an openLS client on OpenLayers.
> Sadly, on the last months I can't see any movement, less towards the routing
> part.
> I am willing to code the missing part of the openLS client that is needed so
> it works against routing petitions. But first I wanted to ask if there is
> someone else already doing this, so we don't duplicate code.
> Also, if someone can give me access to the sandbox, I will be commiting the
> work. If not, I will send you the patch when it is already done.
> Is there anything else (besides the "HowToContribute" wiki page) I need to
> know before start coding?
> [1]http://trac.osgeo.org/openlayers/ticket/3560
> [2]http://dev.openlayers.org/docs/files/OpenLayers/Format/XLS-js.html
> María Arias de Reyna Domínguez
> Área de Operaciones
> Emergya Consultoría
> Tfno: +34 954 51 75 77 / +34 607 43 74 27
> Fax: +34 954 51 64 73
> www.emergya.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20111024/51813268/attachment.html
More information about the Dev
