[OpenLayers-Dev] Re: HTML template popup manager
Noli Sicad
nsicad at gmail.com
Mon Oct 31 18:37:58 EDT 2011
1+ to SmartPopup name.
Then include the 3 examples or more.
1. http://gis.prodevelop.es/olsocial/
2. http://jorix.github.com/SmartPopup/smart-popup.html
3. another one with 3 GeoJSON layers with LayerSwitcher - remove and add
I think it would be good to include more GeoJSON layers aside from
Sprinter GeoJSON, 3 layers with LayerSwitcher.
Noli
On 11/1/11, Xavier Mamano (jorix) <xavier.mamano at gmail.com> wrote:
> Hi Javi,
> To me it seemed an interesting proposal. I think the thing can be:
> * example (draft): http://jorix.github.com/SmartPopup/smart-popup.html
> * code of the control: http://jorix.github.com/SmartPopup/SmartPopup.js
> I think this would be a sufficiently OpenLayers coding, but I'm not
> OpenLayers team member.
> I added an automatic behavior, if the layer has the property "templateId" is
> not necessary to add it.
> TODO:
> * Also allows searching the templates by ajax?.
> * Write tests.
> * Write the method removeLayer.
> * Documenting.
> * Name?: I like the name SmartPopup
> * Constructor options.
> Xavier
> Javier Carrasco wrote:
>> Hello,
>> I wrote a small piece of code to easily add popups to vector layers
>> using html templates.
>> Example: http://gis.prodevelop.es/olsocial/
>> <http://gis.prodevelop.es/olsocial/>
>> SmartPopup is a manager that helps users to add popups to vector layers
>> without dealing with controls or events and without concatenating
>> strings. The name (SmartPopup) is wrong, TemplatePopupManager would be
>> better.
>> I think it could be useful for other users but maybe it is not very
>> OpenLayers-style. Maybe it should be a control instead of a separate
>> object, width and height of the popup and the popup style (like
>> FramedCloud) should be configurable, etc.
>> Could you developers give me some advices to make my code more
>> OpenLayers-style?
>> Thank you
>> Javi
>> Dev mailing list
>> Dev at .osgeo
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> http://osgeo-org.1803224.n2.nabble.com/HTML-template-popup-manager-tp6948565p6949634.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
More information about the Dev
