[OpenLayers-Dev] Re: Openlayers: Check the map content and tell if
the feature exists in the map bound
dr
rykovd at gmail.com
Tue Sep 13 06:14:55 EDT 2011
You syays that your map contains two layers and sLayername is layer name. If
oMapControl.getLayersByName(slayername).length returns 2 it means that your
map contains two layers with the same names?
Denis Rykov
NextGIS
http://www.nextgis.org/
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Openlayers-Check-the-map-content-and-tell-if-the-feature-exists-in-the-map-bound-tp6776147p6786919.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
