[OpenLayers-Dev] Please review this patch (Script protocol)
Volker Mische volker.mische at gmail.com
Mon Sep 19 22:32:52 EDT 2011
Hi all,
I'll bump it up on my TODO list.
I would also love to see it tested against other JSONP APIs. APIs worth
testing that come to my mind are Twitter (what this patch is for),
Flickr and one of Googles. If anyone could test those it would be great,
else I will do it myself.
Cheers,
  Volker
On 09/19/2011 07:20 PM, christopher.schmidt at nokia.com wrote:
> Volker,
> Have you tested this patch with the GeoCouch stuff you're using?
> If it works there, can you add a comment to that ticket? I think
> in general it looks fine, though it would be nice to have some
> tests of some sort to confirm that this is doing what we want. Actually,
> it looks like this patch *breaks* tests; I tossed together
> https://github.com/crschmidt/openlayers-1/commit/6f4be895e292c98d7773bd7be2e0b4f71941a640.patch
> which has a fix for the tests as well.
> If you can test this, and add a comment to the ticket, I think it's
> sane to go ahead with committing at that point.
> -- Chris
> On Sep 7, 2011, at 7:18 AM, ext Volker Mische wrote:
>> On 09/07/2011 08:59 AM, Javier Carrasco wrote:
>>> The script protocol is not working with Twitter service because of the
>>> brackets in the generated requests url.
>>> I just created a ticket and submitted a very small patch here
>>> http://trac.osgeo.org/openlayers/ticket/3486
>>> Thank you for reviewing it
>>> Javi
>> Hi Javi,
>> looks good to me. I haven't tested it, but only read the source.
>> It's sad that OpenLayers 2.11 is almost out already. I would love to squeeze it in, but I can understand if it won't. 2.11 introduces the Script protocol and it would be cool if it won't need to change for 2.12, but it looks like it needs to.
>> Cheers,
>>  Volker
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev mailing list
