[OpenLayers-Dev] Re: wps protocol
Jachym Cepicky jachym.cepicky at gmail.com
Fri Sep 23 21:27:23 EDT 2011
Oh, I had to add one small patch to WPSExecute, to be able to deal with
GML input data, without that, the test page does not work
http://trac.osgeo.org/openlayers/ticket/3517
Jachym
On 24.9.2011 03:18, Jachym Cepicky wrote:
> Hi,
> having more closer look at the WPSExecute format, it basically contains
> *very good* support for Execute requests formating as well. So
> basically, you can ignore my previous email.
> I have written some test page, based on data from the WPS Shootout [1],
> results are very promising:
> So far, tested only Deegree, 52North, Geoserver and Zoo (I know their
> public address), PyWPS (I have it on localhost, public server does not
> work now).
> Results:
> GetCapabilities: all passed
> DescribeProcess (buffer): all passed
> Execute (gml 3.1 input):
>      pywps and zoo did well,
>      geoserver returned correct exception (expecting Geometry, not
> Feature),
>      52North and Deergree failed (Error 500)
> I think, that is great result!
> We will continue the discussion at wps-dev mailing list, I just wanted,
> that the openlayers community is informed about this test.
> Sample test page attached (just copy to examples/ directory)
> As I already said: the OpenLayers.Format.WPS* stuff seems to be pretty
> good - you did very well job, thanks for it. I'm going to use it in the
> Ext-based frontend, I'm supposed to do nowadays.
> We can now drop support for pywps/WPS.js.
> Jachym
More information about the Dev mailing list
