[OpenLayers-Dev] use of GetFeatureInfo with MapServer file
jcbpro81 jean.christophe.bastin at projections.be
Wed Sep 28 07:05:48 EDT 2011
Hello everyone,
I'm new with OpenLayers and MapServer.
I'm looking for a way to get informations on a feature clicked on a map,
like on the following link :
http://openlayers.org/dev/examples/getfeatureinfo-control.html
Here is my environment:
OpenLayers load only one layer of type "OpenLayers.Layer.MapServer".
The mapfile contains 4 postgis layers, and I want to be able to retrieve
informations from one of them.
Here is the JavaScript I have for now according to the GetFeatureInfo, code
found by looking on Google :
	    layer = new OpenLayers.Layer.MapServer("myMap", "url", {map:
'file.map'});
        map.addLayers([layer]);
        map.events.register('click', map, function(evt) {
            document.getElementById("infoResult").innerHTML = "Recherche en
cours..."
            var url = layer.getFullRequestString({
                REQUEST: "GetFeatureInfo",
               	EXCEPTIONS: "application/vnd.ogc.se_xml",
                STYLES: "",
                BBOX: map.getExtent().toBBOX(),
                X: evt.xy.x,
                Y: evt.xy.y,
                QUERY_LAYERS: "myLayer",
                FEATURE_COUNT: 1,
                WIDTH: map.size.w,
                HEIGHT: map.size.h,
                INFO_FORMAT: 'text/html'
            //alert(url);
        	OpenLayers.loadURL(url, '', this, setInfoResult);
         	Event.stop(evt);
	function setInfoResult(response) {
        //alert(response);
		document.getElementById("infoResult").innerHTML = response.responseText;
When I click anywhere on the map, the "infoResult" shows "?PNG  " (the
display is a square next to "PNG" characters).
So I'm questionning myself on what I'm doing wrong.
About the QUERY_LAYERS parameter, with value "myLayer", do I have to put the
name of the layer loaded with OpenLayers ("myMap") or the name of a layer
inside of my mapfile ("myLayer") ?
Is this code can work with postgis layers ?
Do I have to work in another way ?
I find that OpenLayers online help
(http://dev.openlayers.org/releases/OpenLayers-2.9/doc/apidocs/index/General.html)
isn't really "user friendly" and hard to understand.
I spent lot of days to be able to simply display a map.
Any help will be much apprecied.
Thanks in advance.
Regards,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/use-of-GetFeatureInfo-with-MapServer-file-tp6839763p6839763.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
