[OpenLayers-Dev] Tile issue, points layer cut
Peter Körner osm-lists at mazdermind.de
Wed Sep 28 07:53:53 EDT 2011
Am 28.09.2011 13:39, schrieb jcbpro81:
> My questions is how can I configure OpenLayers (or MapServer maybe ?) to
> avoid that ?
The tiles are generated in MapServer, so that's the place to look for.
Usually we create a buffer around the bbox that needs to be rendered. In
mapnik-xml it's the buffer-size argument in the <Map />-tag, there
should be something similar with MapServer.
Peter
More information about the Dev mailing list
