[OpenLayers-Dev] Alternative to Proj4JS
Michael Adair
madair at dmsolutions.ca
Thu Apr 5 10:11:40 EDT 2012
Peter,
A new release of Proj4js with the MIT style license is now available.
Mike
On 27/03/2012 9:40 AM, Michael Adair wrote:
> Peter,
> Or we can also change the Proj4js license. IANAL and I don't pretend
> to understand subtleties of licenses but if LGPL is a blocker, I'm all
> in favour of changing that so that the Proj4js gets used as widely as
> possible. I'll raise the issue on the MetaCRS list.
> Mike
> On 27/03/2012 7:00 AM, Day, Peter A (EXP) wrote:
>> I have been part of a team developing a system for a customer which
>> uses Openlayers as its map interface. We use Proj4JS to perform the
>> coordinate conversions.
>> Because both Openlayers and Proj4JS are Open Source we have to get
>> these approved for use. Openlayers is no problem but unfortunately
>> the corporate lawyers have jumped on Proj4JS as it uses the L-GPL
>> license. I don't pretend to understand the reasons behind this but it
>> means that we cannot use it.
>> Does anyone know of an alternative Javascript library -- either OS or
>> commercial -- that we could use to replace Proj4JS?
>> (What is most annoying is that Proj4 and the Java conversion use MIT
>> licences which would have been acceptable)
>> Thanks
>> UkPad
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120405/7def68fb/attachment.html
More information about the Dev
