[OpenLayers-Dev] SVG external graphic preserves aspect ratio
Harris Hudson
hhudson at katmandu.org
Thu Apr 12 05:03:29 EDT 2012
You might want to try changing your crucero.svg file in your
example and modify the main <svg> element (at line 4) and add
the preserveAspectRatio="none" attribute.
Eg; <svg preserveAspectRatio="none" version="1.1" ...
Regards,
Harris.
> Hi,
> I'm trying to apply a SVG external graphic to a points layer. What I
> need is that the graphic size will be scale dependant and not preserve
> the aspect ratio.
> What I've found is whatever graphicHeight and graphicWidth I set to the
> externalGraphic, the SVG is rendered preserving the aspect ratio... If I
> use png the graphic is drawn correctly.
> The style definition I'm using is very simple:
> var style = new OpenLayers.Style(OpenLayers.Util.applyDefaults({
> graphicWidth: 100 ,
> graphicHeight: 600 ,
> externalGraphic: 'img/petrolero.svg',
> fill: false,
> stroke: false,
> pointRadius: 0,
> rotation: "${rotation}",
> fillOpacity: 1
> }, OpenLayers.Feature.Vector.style["default"]));
> var styleMap = new OpenLayers.StyleMap({"default": style,
> "select": style});
> layer = new OpenLayers.Layer.Vector('Points', {
> styleMap: styleMap
> Anyway, I've published an example [1] of what's happening. The green
> boats are PNG being scaled correctly, the brown ones are SVG not being
> scaled correctly as they preserve the aspect ratio, both have the same
> graphicHeight and graphicWidth. Sometimes when the layer is loaded the
> SVG is drawn correctly but when a zoom is applied then happens the
> aspect ratio issue...
> Am I missing something? Is there a way to use SVG in the way I need?
> Best regards.
> [1] http://gis.prodevelop.es/openlayers/svg.html
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
