[OpenLayers-Dev] SVG external graphic preserves aspect ratio
Alberto Romeu
aromeu at prodevelop.es
Thu Apr 12 03:17:39 EDT 2012
Hi Harris,
it worked!
Alberto Romeu
Prodevelop SL, Valencia (España)
Tlf.: 96.351.06.12 -- Fax: 96.351.09.68
http://www.prodevelop.es
El 12/04/12 11:03, Harris Hudson escribió:
> Hi,
> You might want to try changing your crucero.svg file in your
> example and modify the main<svg> element (at line 4) and add
> the preserveAspectRatio="none" attribute.
> Eg;<svg preserveAspectRatio="none" version="1.1" ...
> Regards,
> Harris.
>> Hi,
>> I'm trying to apply a SVG external graphic to a points layer. What I
>> need is that the graphic size will be scale dependant and not preserve
>> the aspect ratio.
>> What I've found is whatever graphicHeight and graphicWidth I set to the
>> externalGraphic, the SVG is rendered preserving the aspect ratio... If I
>> use png the graphic is drawn correctly.
>> The style definition I'm using is very simple:
>> var style = new OpenLayers.Style(OpenLayers.Util.applyDefaults({
>> graphicWidth: 100 ,
>> graphicHeight: 600 ,
>> externalGraphic: 'img/petrolero.svg',
>> fill: false,
>> stroke: false,
>> pointRadius: 0,
>> rotation: "${rotation}",
>> fillOpacity: 1
>> }, OpenLayers.Feature.Vector.style["default"]));
>> var styleMap = new OpenLayers.StyleMap({"default": style,
>> "select": style});
>> layer = new OpenLayers.Layer.Vector('Points', {
>> styleMap: styleMap
>> Anyway, I've published an example [1] of what's happening. The green
>> boats are PNG being scaled correctly, the brown ones are SVG not being
>> scaled correctly as they preserve the aspect ratio, both have the same
>> graphicHeight and graphicWidth. Sometimes when the layer is loaded the
>> SVG is drawn correctly but when a zoom is applied then happens the
>> aspect ratio issue...
>> Am I missing something? Is there a way to use SVG in the way I need?
>> Best regards.
>> [1] http://gis.prodevelop.es/openlayers/svg.html
>> Dev mailing list
>> Dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
More information about the Dev
