[OpenLayers-Dev] ANNOUNCEMENT: OpenLayers 2.12 RC2!
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Apr 24 16:09:08 EDT 2012
The OpenLayers dev team is proud to announce the 2nd release candidate
of OpenLayers 2.12! RC2 comes about one month after RC1, and fixes a
number of things:
The strategy-cluster, strategy-bbox and strategy-paging examples
are back to order. They now rely on the Flickr API. Issue 345.
The Layer.Grid tests pass again. Issue 352.
The Zoom buttons are now universally visible. They're blue with a
transparent white background. Issues 353 and 355.
The CSS rule enabling tile animation is back in the mobile
examples stylesheet. Issue 356.
The API docs for the projection option in Map and Layer have been
improved. Issue 358.
The proj4js examples have been improved. Issue 363.
Some mess with the license, readme, and authors files has been
cleaned up. Issues 364 and 376.
Tile animations are now disabled by default for single tile
layers. Issues 365 and 384.
The unused framedCloud.css file has been removed. Issue 377.
The CacheWrite control now works correctly for tiles with a cross
origin keyword. Issue 388.
The detection of the OpenLayers script location is now more
robust. Issue 390.
Grid layers are no longer misplaced when changing their
visibility. Issue 393.
The mapbox example now looks better. Issue 395.
The Bing attribution is no longer incorrect because of axis order.
Issues 398 and 400.
Adding an overview map to an OSM map now works as expected. Issue 399.
The Util tests now pass in Chrome. Issue 403.
The TMS zoomOffset tests no longer produce NaN values for
maxResolution. Issue 406.
The Bing attribution is now correct when setting maxResolution. Issue 419.
The map pan() function no longer triggers moveend twice. Issue 426.
setOpacity on layers based on iframe tiles now works in FireFox. Issue 432.
See <https://github.com/openlayers/openlayers/issues?milestone=3&state=closed>
for details.
We invite you to help us test the 2.12 release candidate! To test 2.12
in your applications, include the following tag in your
OpenLayers-powered page:
<script src="http://openlayers.org/api/2.12-rc2/OpenLayers.js"></script>
As always, the source is available at
<http://openlayers.org/download/>. Bug reports can be filed in GitHub
at <https://github.com/openlayers/openlayers/issues>.
Thanks!
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
