[OpenLayers-Dev] Rearranging stack order of layers
Tim-Hinnerk Heuer
th.heuer at gmail.com
Fri Aug 10 04:22:21 PDT 2012
How about a function/extension to OpenLayers that does this?
OpenLayers.Map.prototype.swapLayers = function(firstLayer, secondLayer) {
var delta = this.getNumLayers() - 2;
map.raiseLayer(secondLayer, -delta);
map.raiseLayer(firstLayer, delta);
// in your code you would then call:
map.addLayer(layer_e); // if you haven't done so already
map.swapLayers(layer_b, layer_e);
Haven't tested this but believe it works assuming the code below works.
Cheers,
Tim
Tim-Hinnerk Heuer
Twitter: @geekdenz
Blog: http://www.thheuer.com
On 10 August 2012 21:29, Jason Lee <jaslee.st at gmail.com> wrote:
> Oops, let's make that example more generic(!)
> lyrNum = 2;
> var delta = map.getNumLayers() - lyrNum;
> map.raiseLayer(layer_e, -delta);
> map.raiseLayer(layer_b, delta);
> Jason
> On Fri, Aug 10, 2012 at 10:26 AM, Jason Lee <jaslee.st at gmail.com> wrote:
>> Don't know if it is the best solution, but I am now using
>> "map.raiseLayer()" like so:-
>> lyrNum = 2;
>> map.raiseLayer(layer, -delta);
>> map.raiseLayer(netLayer, delta);
>> This seems to do the trick.
>> Jason
>> On Fri, Aug 10, 2012 at 9:55 AM, Jason Lee <jaslee.st at gmail.com> wrote:
>>> Hi,
>>> I have an OpenLayers application which initially has 4 layers, called
>>> (a),(b),(c) & (d). The app then allows the creation of a new layer (e)
>>> which I want it to "swap" places with layer (b) so that the order should be
>>> (a),(e),(c),(d),(b).
>>> I use the map.setLayerIndex and layer.getZIndex to try and do this but I
>>> realise that the layers are in a FIFO like queue, so when I temporarily
>>> re-assign layer (b) the other layers automatically reorder themselves to
>>> (a),(c),(d),(e) ...or at least that's what I think it happening.
>>> Could anyone show me how I can simply swap the z-order of 2 layers?
>>> Thanks
>>> Jason
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120810/f4baa210/attachment.html>
More information about the Dev
