[OpenLayers-Dev] vector symbols and canvas renderer
Andreas Hocevar
ahocevar at opengeo.org
Thu Feb 9 07:35:30 EST 2012
graphicNames are currently not implemented for the Canvas renderer. I
don't think it would be too hard to add, so if you are willing to
contribute and give it a try, I can maybe help you a bit with the
implementation.
Andreas.
On Wed, Feb 8, 2012 at 10:20 PM, <jansen at nieuwland.nl> wrote:
> Hi there,
> I was wondering if there is any way to get (well-known) graphicNames to work
> on a OpenLayers map using the canvas renderer? I am developing an HTML5
> application for Android devices which use canvas renderer by default and do
> not support any other renderers as far as I understand? I need square,
> triangle and star symbols on a vector layer. The use of externalGraphics as
> alternative causes trouble with labeling. Any advice is much appreciated!!
> Thanks a lot,
> Jan
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
