[OpenLayers-Dev] Opera has a problem with SVG
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Mon Feb 13 11:31:16 EST 2012
The top vector layer increases when pressing "mousedown" holding down
control key.
Once this has happened the layer is displayed incorrectly: the features are
increased and its location is moved. So the layer is useless and the user
must reload the map.
As a consequence with Opera is not possible to use "keyMask:
OpenLayers.Handler.MOD_CTRL" in the handlers if the map contains vector
layers.
Please see: http://trac.osgeo.org/openlayers/ticket/3290
Try Opera & mousedown+CTRL using:
http://openlayers.org/dev/examples/select-feature.html
(This problem is reported by some users, I just do echo)
Xavier Mamano
View this message in context: http://osgeo-org.1560.n6.nabble.com/Opera-has-a-problem-with-SVG-tp4465580p4465580.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
