[OpenLayers-Dev] ship only with minimal build for 2.12
Tom MacWright
tom at macwright.org
Wed Feb 22 13:26:20 EST 2012
(resending, forgot to reply all)
That's a larger problem: OpenLayers, the website, and the docs, doesn't
talk about its modularity and what you do when when you don't have a
component, or how you check to see if you have a component. That docs issue
needs to be fixed, not avoided.
Enough with the filesize comparisons to WMS tiles or whatever; OpenLayers
is a behemoth compared to other Javascript libraries - it's several times
the size of jQuery, Backbone, Leaflet, and whatever else users have tried
out, and for reasons that totally don't matter to 90% of users. OpenLayers
is 177kb gzipped - that's 6x jQuery.
On Wed, Feb 22, 2012 at 1:00 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> I can already smell the questions on the mailing list and elsewhere
> from people finding something not working when they go beyond the
> "light" use case...
> Still -1. What's so bad about a cacheable script of less than 1MB
> gzipped, compared to a single non cacheable set of WMS tiles for a
> fullscreen map with several MB?
> Andreas.
> On Wed, Feb 22, 2012 at 6:48 PM, Tom MacWright <tom at macwright.org> wrote:
> > There's no need for the current light build to be the one that ships:
> it'd
> > be simple to expand and specialize it a bit more to align with what's
> needed
> > by the Leaflet/Google Maps usecase.
> > Tom
> > On Wed, Feb 22, 2012 at 12:46 PM, Andreas Hocevar <ahocevar at opengeo.org>
> > wrote:
> >> The light build with the current lite configuration would be useless
> >> for most users. As Tom says, many people won't be able to use the
> >> python based build tool, and what then happens is much worse than
> >> people using a full build: they'll be using the debug loader or the
> >> hosted version from openlayers.org.
> >> So I'm -1 on shipping a light build.
> >> Andreas.
> >> On Wed, Feb 22, 2012 at 5:11 PM, Tom MacWright <tom at macwright.org>
> wrote:
> >> > Absolutely. If OpenLayers doesn't provide a jQuery-UI like build
> creator
> >> > (something that I tried to do with OpenLayerer, but that build-tool
> >> > refactoring was never accepted), then there should be a light build
> >> > distributed by default. The expectations of the user to run the Python
> >> > scripts are way too great for the use-case of just downloading and
> >> > running
> >> > the thing, even if they seems simple for developers. Like, some guy
> >> > making
> >> > an HTML website on a Windows machine would have to install Python from
> >> > scratch: it isn't going to happen.
> >> > Tom
> >> > On Wed, Feb 22, 2012 at 11:06 AM, Bart van den Eijnden
> >> > <bartvde at opengeo.org>
> >> > wrote:
> >> >> As suggested by Antoine on Twitter, and I agree. Clearly a lot of
> >> >> people
> >> >> are still using a full build, even if we tell people not to.
> >> >> So what about only shipping a minimal build for 2.12?
> >> >> https://twitter.com/#!/bartvdeijnden/status/172328188704333825
> >> >> https://twitter.com/#!/brankgnol/status/172345191670358016
> >> >> Best regards,
> >> >> Bart
> >> >> OpenGeo - http://opengeo.org
> >> >> Expert service straight from the developers.
> >> >> _______________________________________________
> >> >> Dev mailing list
> >> >> Dev at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> >> > Dev mailing list
> >> Andreas Hocevar
> >> OpenGeo - http://opengeo.org/
> Andreas Hocevar
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120222/d2efb9d3/attachment-0001.html
More information about the Dev
