[OpenLayers-Dev] OpenLayers.Format.SLD - Graphics support (mostly)
m0n0
ole at monochrom.net
Mon Feb 27 07:19:47 EST 2012
Hello there,
this patch is not getting better when not beeing published, it's laying
around here for a few month. It's not so clean, but maybe someone is
interested.
1. I needed to change 2 XML Schema attributes to make it work with
ArcGIS 10. That's included in the patch, but it has
nothing to do with SLD Graphics support.
2. All the other stuff is there to provide Graphics support within SLD
( that was missing, but I needed it ). Works well for me.
Tested against random WMS and ArcGIS 10 WMS.
Greets,
m
Index: v1.js
--- v1.js (revision 12170)
+++ v1.js (working copy)
@@ -534,8 +534,7 @@
var root = this.createElementNSPlus(
"sld:StyledLayerDescriptor",
{attributes: {
- "version": this.VERSION,
- "xsi:schemaLocation": this.schemaLocation
+ "version": this.VERSION
@@ -543,6 +542,8 @@
// at the root level (see ticket:2166).
root.setAttribute("xmlns:ogc", this.namespaces.ogc);
root.setAttribute("xmlns:gml", this.namespaces.gml);
+ root.setAttribute("xmlns:xsi", this.namespaces.xsi);
+ root.setAttribute("xsi:schemaLocation", this.schemaLocation );
// add in optional name
if(sld.name) {
@@ -792,6 +793,7 @@
// GraphicStroke here
// add in CssParameters
if(symbolizer.strokeColor != undefined) {
this.writeNode(
"CssParameter",
@@ -982,19 +984,25 @@
"PolygonSymbolizer": function(symbolizer) {
var node = this.createElementNSPlus("sld:PolygonSymbolizer");
- if(symbolizer.fill !== false) {
- this.writeNode("Fill", symbolizer, node);
+ if (symbolizer.fill !== false) {
+ this.writeNode("Fill", symbolizer, node);
if(symbolizer.stroke !== false) {
this.writeNode("Stroke", symbolizer, node);
return node;
"Fill": function(symbolizer) {
var node = this.createElementNSPlus("sld:Fill");
- // GraphicFill here
+ if (symbolizer.graphicName != undefined || symbolizer.externalGraphic != undefined ) {
+ if ((symbolizer.graphicName != null && symbolizer.graphicName != "")
+ || (symbolizer.externalGraphic != null && symbolizer.externalGraphic != "") ) {
+ this.writeNode("GraphicFill", symbolizer, node);
if(symbolizer.fillColor) {
this.writeNode(
@@ -1017,9 +1025,14 @@
this.writeNode("Graphic", symbolizer, node);
return node;
+ "GraphicFill": function(symbolizer){
+ var node = this.createElementNSPlus("sld:GraphicFill");
+ this.writeNode("Graphic", symbolizer, node);
+ return node;
"Graphic": function(symbolizer) {
var node = this.createElementNSPlus("sld:Graphic");
- if(symbolizer.externalGraphic != undefined) {
+ if(symbolizer.externalGraphic != undefined && symbolizer.externalGraphic != "") {
this.writeNode("ExternalGraphic", symbolizer, node);
} else {
this.writeNode("Mark", symbolizer, node);
@@ -1048,12 +1061,22 @@
"Mark": function(symbolizer) {
var node = this.createElementNSPlus("sld:Mark");
- if(symbolizer.graphicName) {
- this.writeNode("WellKnownName", symbolizer.graphicName, node);
- if (symbolizer.fill !== false) {
+ if (symbolizer.graphicName != null && symbolizer.graphicName != "" && symbolizer.graphicName != undefined ) {
+ this.writeNode("WellKnownName", symbolizer.graphicName, node);
+ // manually write fill node to prevent recursion
+ if( symbolizer.fillColor != undefined || symbolizer.fill != false ){
+ var ob = {fillColor: symbolizer.fillColor};
+ if( symbolizer.fillOpacity != undefined ){
+ ob.fillOpacity = symbolizer.fillOpacity;
+ this.writeNode("Fill", ob, node);
+ else {
if (symbolizer.stroke !== false) {
More information about the Dev
