[OpenLayers-Dev] OpenLayers.Format.SLD - Graphics support (mostly)
Andreas Hocevar
ahocevar at opengeo.org
Mon Feb 27 07:30:22 EST 2012
thanks for your work on this. Your patch would likely get more
attention if turned into a pull request on github.
Andreas.
On Mon, Feb 27, 2012 at 1:19 PM, m0n0 <ole at monochrom.net> wrote:
> Hello there,
> this patch is not getting better when not beeing published, it's laying
> around here for a few month. It's not so clean, but maybe someone is
> interested.
> 1. I needed to change 2 XML Schema attributes to make it work with ArcGIS
> 10. That's included in the patch, but it has
> nothing to do with SLD Graphics support.
> 2. All the other stuff is there to provide Graphics support within SLD (
> that was missing, but I needed it ). Works well for me.
> Tested against random WMS and ArcGIS 10 WMS.
> Greets,
> m
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
