[OpenLayers-Dev] using wrapDataLine in Markers layer
Phil Scadden
p.scadden at gns.cri.nz
Wed Jul 18 18:59:21 PDT 2012
>The problem I am now having is if the map center is (165,35) and the vector
>symbol is (170,45) then when I select the object the map is recentered at
I think you post your selection code. I can think of no reason why the
map should recenter on selection.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev
