[OpenLayers-Dev] using wrapDataLine in Markers layer
ron
thorsonr at saic.com
Wed Jul 18 17:04:42 PDT 2012
Thanks.
I solved the problem by putting the symbol objects into a vector layer. Now
the objects appear on both sides of the date line.
I also changed to a GeoTiff tiled map for the base map.
The problem I am now having is if the map center is (165,35) and the vector
symbol is (170,45) then when I select the object the map is recentered at
(0,0).
Is there a way to disable the map redraw event?
View this message in context: http://osgeo-org.1560.n6.nabble.com/using-wrapDataLine-in-Markers-layer-tp4988854p4989215.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
