[OpenLayers-Dev] using wrapDataLine in Markers layer
Phil Scadden
p.scadden at gns.cri.nz
Wed Jul 18 20:26:32 PDT 2012
On 19/07/2012 3:07 p.m., ron wrote:
> It is the FramedCloud popup that is causing the redraw...I can likely work
> around this by sending the object data to another HTML page and not using a
> popup.
You could also set the popup properties: panMapIfOutofView to false and
keepInMap to true.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
More information about the Dev
