[OpenLayers-Dev] using wrapDataLine in Markers layer
ron
thorsonr at saic.com
Thu Jul 19 07:37:49 PDT 2012
Thanks...setting these properties prevefnted the map from refreshing but the
point in the western hemisphere popup did not display (likely because the
"translated" anchor point was outside map)...the fix I used was to use the
map center for the popup anchor.
Aloha.
View this message in context: http://osgeo-org.1560.n6.nabble.com/using-wrapDataLine-in-Markers-layer-tp4988854p4989381.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
