[OpenLayers-Dev] selectFeature's selectStyle cannot accept propertyStyle?
Alexandre Dubé
adube at mapgears.com
Mon Jul 30 05:13:48 PDT 2012
Instead of defining a selectStyle in the control, you could try
setting a styleMap to your layer object. This example should point you
to the right direction since it uses a '${type}' symbolizer value and a
select control :
http://openlayers.org/dev/examples/graphic-name.html
HTH,
Alexandre
P.S. Btw, this question would have been more suitable for the users
mailing list.
On 12-07-30 05:52 AM, BERÉNYI Attila wrote:
> Hi!
> I wanted to use the selectFeature control's selectStyle property to
> display a property-based label for the selected features, however, it
> seems that the selectStyle property doesn't support property-based
> styling.
> Example here:
> http://gislab.hu/ol/selectFeature-selectStyle-propertyStyle.html
> Is this a bug or am I doing something wrong?
> BR,
> Attila
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120730/51bf7ef4/attachment.html>
More information about the Dev
