[OpenLayers-Dev] selectFeature's selectStyle cannot accept propertyStyle?
BERÉNYI Attila
aberenyi at gislab.hu
Mon Jul 30 11:56:03 PDT 2012
thank you for your response, it seems like I have not been clear enough.
If every single vector feature has its own style, the layer's styleMap
object cannot be used (it looks like it is ignored, check here:
http://gislab.hu/ol/selectFeature-selectStyle-propertyStyle-1.html) that's
why I try to use selectStyle.
I've update the original example as well:
http://gislab.hu/ol/selectFeature-selectStyle-propertyStyle.html.
BR,
Attila
2012/7/30 Alexandre Dubé <adube at mapgears.com>
> Hi,
> Instead of defining a selectStyle in the control, you could try setting
> a styleMap to your layer object. This example should point you to the
> right direction since it uses a '${type}' symbolizer value and a select
> control :
> http://openlayers.org/dev/examples/graphic-name.html
> HTH,
> Alexandre
> P.S. Btw, this question would have been more suitable for the users
> mailing list.
> On 12-07-30 05:52 AM, BERÉNYI Attila wrote:
> Hi!
> I wanted to use the selectFeature control's selectStyle property to
> display a property-based label for the selected features, however, it seems
> that the selectStyle property doesn't support property-based styling.
> Example here:
> Is this a bug or am I doing something wrong?
> BR,
> Attila
> Dev mailing listDev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/openlayers-dev
> Alexandre Dubé
> Mapgearswww.mapgears.com
> Dev mailing list
BERÉNYI Attila, PhD
ügyvezető igazgató
GISLab Hungary Kft.
1031 Budapest, Kadosa utca 59.
+36 20 457 1800
URL: <http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120730/8a225469/attachment.html>
More information about the Dev
