[OpenLayers-Dev] Open Layer back button
Xavier Mamano (jorix)
xavier.mamano at gmail.com
Wed Jun 6 14:15:08 PDT 2012
Have you seen the example
http://www.openlayers.org/dev/examples/navigation-history.html ?
Xavier Mamano
ramy.sehar wrote
> Hi,
> I have a website similar to MLS.ca where user can search a property with
> criteria and select property upon clicking on the map.
> It is defined in 1 page(search criteria, map and listing).I have asked to
> add functionality of back button.
> This button will take to the previous state of the map(zoom level etc). I
> am working on it for the last few hours and didn't
> go any far, totally confused after seeing all those JS files...
> I need your help/ guidance to do it.
> P.S. It doesn't use any query string value to control bounding box or any
> other variable
> Thanks a lot in advane
> Sonia
View this message in context: http://osgeo-org.1560.n6.nabble.com/Open-Layer-back-button-tp4979581p4979592.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
