[OpenLayers-Dev] Issue - vector feature following map center on map move
Alexandre Dube adube at mapgears.com
Fri Jun 15 05:36:51 PDT 2012
   Does anyone have an idea for solving or working around this issue ?
Regards,
Alexandre
On 12-06-08 10:21 AM, Alexandre Dube wrote:
> You're right, it's not an SVG issue.  The issue is the same with
> [Canvas].  I tested in IE (VML) and the feature disappears when it
> hits the edge.
> Do you know if there could be quick way to work around the issue ?
> [Canvas]
> http://dev8.mapgears.com/openlayers/2.12-rc6/examples/ad-vector-issue-map-move.html?renderer=Canvas
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
