[OpenLayers-Dev] Issue - vector feature following map center on map move
Alexandre Dube
adube at mapgears.com
Fri Jun 8 07:21:54 PDT 2012
Eric,
On 12-06-08 09:15 AM, Eric Lemoine wrote:
> Unknown to me. You're saying this is a SVG issue, have you actually
> tried in IE or in FireFox using renderers: ['Canvas'] in the vector
> layer? When inspecting the svg element with the debugger you can see
> the polygon (path element) being removed. Although not fully sure I
> think this is a longstanding bug in OpenLayers.
You're right, it's not an SVG issue. The issue is the same with
[Canvas]. I tested in IE (VML) and the feature disappears when it hits
the edge.
Do you know if there could be quick way to work around the issue ?
Regards,
Alexandre
[Canvas]
http://dev8.mapgears.com/openlayers/2.12-rc6/examples/ad-vector-issue-map-move.html?renderer=Canvas
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
