[OpenLayers-Dev] Issue - vector feature following map center on map move
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Jun 8 06:15:51 PDT 2012
On Thu, Jun 7, 2012 at 5:52 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Hi,
> While dragging the map and moving a vector feature to the center of the map
> on "move" event triggered, I face a strange issue. The feature at some
> point seems to hit the border of the renderer box and begins disappearing.
> When releasing the drag, it reappears as a whole again. From what I
> understand, it seems like a SVG issue. I think the renderer box isn't
> recalculated while dragging, only when it ends.
> Is this a known issue ? I tried it in 2.11 and 2.12-rc6 and they both show
> it.
Unknown to me. You're saying this is a SVG issue, have you actually
tried in IE or in FireFox using renderers: ['Canvas'] in the vector
layer? When inspecting the svg element with the debugger you can see
the polygon (path element) being removed. Although not fully sure I
think this is a longstanding bug in OpenLayers.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
