[OpenLayers-Dev] 2.12 - current state of affairs
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Mar 5 09:11:13 EST 2012
On Mon, Mar 5, 2012 at 11:51 AM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Mon, Mar 5, 2012 at 11:34 AM, Peter Robins
> <openlayers at peterrobins.co.uk> wrote:
>> On 5 March 2012 10:01, Eric Lemoine <eric.lemoine at camptocamp.com> wrote:
>>> #248 Allow map and layer coordinates to be provided as latitude and longitude.
>> as stated in the pull request, this includes improvements to docs,
>> and, for consistency, giving Map.minExtent the same logic as the other
>> extents. I think this should go in 2.12 regardless of whether the full
>> #248 is merged. If you like, I can issue a new pull request for these.
> Doc changes are welcome.
>>> #207 Change Protocol/Script registry to object
>> don't see what this one has to do with failing tests. It only affects
>> Protocol/Script. (If you're saying no-one has time to review, ok)
> It's just that code changes may break things (tests in particular).
If you can confirm that the tests pass in FF, IE 8+, Chrome and Safari
I can consider your patch for 2.12. Thank you.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
