[OpenLayers-Dev] 2.12 - current state of affairs
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Mar 5 05:51:17 EST 2012
On Mon, Mar 5, 2012 at 11:34 AM, Peter Robins
<openlayers at peterrobins.co.uk> wrote:
> On 5 March 2012 10:01, Eric Lemoine <eric.lemoine at camptocamp.com> wrote:
>> #248 Allow map and layer coordinates to be provided as latitude and longitude.
> as stated in the pull request, this includes improvements to docs,
> and, for consistency, giving Map.minExtent the same logic as the other
> extents. I think this should go in 2.12 regardless of whether the full
> #248 is merged. If you like, I can issue a new pull request for these.
Doc changes are welcome.
>> #207 Change Protocol/Script registry to object
> don't see what this one has to do with failing tests. It only affects
> Protocol/Script. (If you're saying no-one has time to review, ok)
It's just that code changes may break things (tests in particular).
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
