[OpenLayers-Dev] [MOTION] create 2.12 branch
Andreas Hocevar
ahocevar at opengeo.org
Thu Mar 8 12:51:09 EST 2012
Hi Eric,
first of all, thanks a lot for taking on the release work - which
isn't trivial now that both GitHub and trac need to be managed.
I am +1 on branching off 2.12 now under the terms that you suggested
(i.e. pull requests for 2.12 are still possible, and existing pull
requests in the 2.12 milestone will be considered).
I added #248 to the 2.12 milestone again, in the hope that there will
be at least some discussion about it. I would like to have all the
pull requests that are currently open in the 2.12 milestone in the
final release.
Andreas.
On Thu, Mar 8, 2012 at 6:08 PM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> Hi
> I have moved all the open Trac tickets out of the 2.12 milestone. We
> still have three open issues in GitHub [*]. I'd still like to create
> the 2.12 branch in GitHub, to be able to easily control what goes into
> 2.12 and what does not. We have all the tests pass in FF 10, Chrome
> 17, IE 8, IE 9, and Safari 5.1.2, and I'd really like to keep that.
> PSC members, please give your approval or disapproval.
> When the 2.12 branch is created pull requests for 2.12 will need to
> target the 2.12 branch. And people submitting pull requests for 2.12
> will need to make sure tests pass in the aforementioned browsers.
> Thanks.
> [*] <https://github.com/openlayers/openlayers/issues?milestone=1&sort=created&direction=desc&state=open>
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
