[OpenLayers-Dev] [MOTION] create 2.12 branch
Eric Lemoine
eric.lemoine at camptocamp.com
Fri Mar 9 18:36:46 EST 2012
On Thu, Mar 8, 2012 at 6:51 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi Eric,
> first of all, thanks a lot for taking on the release work - which
> isn't trivial now that both GitHub and trac need to be managed.
> I am +1 on branching off 2.12 now under the terms that you suggested
> (i.e. pull requests for 2.12 are still possible, and existing pull
> requests in the 2.12 milestone will be considered).
> I added #248 to the 2.12 milestone again, in the hope that there will
> be at least some discussion about it. I would like to have all the
> pull requests that are currently open in the 2.12 milestone in the
> final release.
Thanks for responding Andreas. I'll create the branch on monday if I
don't get any push back until then.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
