[OpenLayers-Dev] [MOTION] create 2.12 branch
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Mar 12 11:48:27 EDT 2012
On Sat, Mar 10, 2012 at 12:36 AM, Eric Lemoine
<eric.lemoine at camptocamp.com> wrote:
> On Thu, Mar 8, 2012 at 6:51 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Hi Eric,
>> first of all, thanks a lot for taking on the release work - which
>> isn't trivial now that both GitHub and trac need to be managed.
>> I am +1 on branching off 2.12 now under the terms that you suggested
>> (i.e. pull requests for 2.12 are still possible, and existing pull
>> requests in the 2.12 milestone will be considered).
>> I added #248 to the 2.12 milestone again, in the hope that there will
>> be at least some discussion about it. I would like to have all the
>> pull requests that are currently open in the 2.12 milestone in the
>> final release.
> Thanks for responding Andreas. I'll create the branch on monday if I
> don't get any push back until then.
Ok. Branch 2.12 is created. At this point we have one issue left for
2.12: <https://github.com/openlayers/openlayers/issues?milestone=1&sort=created&direction=desc&state=open>.
I think Matt is going to tackle that one.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
